gsuttor
Jun 09, 2011Aspirant
Minecraft Linux on ReadyNas Pro Pioneer
Is it possible to run the Linux version of Minecraft server on the ReadyNas Pro Pioneer? Has anyone attempted it? If so please share. I'd love to run the box as a small home server for this. (2-3 p...
gsuttor
Jun 25, 2011Aspirant
I definitely ham-fisted something here... the email report as follows:
***** File system check performed at Sun Jun 26 08:57:15 EST 2011 ***** fsck 1.41.14 (22-Dec-2010) e2fsck 1.41.14 (22-Dec-2010) /dev/c/c was not cleanly unmounted, check forced.
Pass 1: Checking inodes, blocks, and sizes Extended attribute block 574029952 has reference count 4, should be 2. Fix? yes
Pass 2: Checking directory structure
Entry 'level.dat' in /backup/minecraft/world (62435332) has deleted/unused inode 62435350. Clear? yes
Entry 'level.dat_old' in /backup/minecraft/world (62435332) has deleted/unused inode 62435353. Clear? yes
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information Block bitmap differences: -(499648372--499648373) Fix? yes
Free blocks count wrong for group #15248 (27666, counted=27668).
Fix? yes
Free blocks count wrong (596547550, counted=596547552).
Fix? yes
Inode bitmap differences: -62435351 -62435353 Fix? yes
Free inodes count wrong for group #15243 (4072, counted=4074).
Fix? yes
Free inodes count wrong (151647387, counted=151647389).
Fix? yes
/dev/c/c: ***** FILE SYSTEM WAS MODIFIED *****
/dev/c/c: 68451/151715840 files (45.0% non-contiguous), 617179168/1213726720 blocks
Fix? yes
Fix? yes
Fix? yes
Fix? yes
