gsuttor
Jun 09, 2011Aspirant
Minecraft Linux on ReadyNas Pro Pioneer
Is it possible to run the Linux version of Minecraft server on the ReadyNas Pro Pioneer? Has anyone attempted it? If so please share. I'd love to run the box as a small home server for this. (2-3 p...
budda1
Jul 06, 2014Aspirant
I upgraded the Minecraft server jar in the directory mentioned above and still nothing was working.
Running the command from the shell revealed the problem:
All the instructions I found online kept referencing an existing eula.txt file to edit. There was none, so I made one and stuck
Now my desktop Client 1.7 can see the ReadyNAS MC server and I can connect fine, however i'm now greeted with an authentication problem. Hopefully at the Mojang end?
Any ideas on the cause ?
# java -Xmx1024M -Xms1024M -jar /etc/frontview/addons/bin/MINECRAFT/minecraft_server.jar nogui
[02:26:55] [Server thread/INFO]: Starting minecraft server version 1.7.10
[02:26:55] [Server thread/INFO]: Loading properties
[02:26:55] [Server thread/WARN]: server.properties does not exist
[02:26:55] [Server thread/INFO]: Generating new properties file
[02:26:55] [Server thread/WARN]: Failed to load eula.txt
[02:26:55] [Server thread/INFO]: You need to agree to the EULA in order to run the server. Go to eula.txt for more info.
[02:26:55] [Server thread/INFO]: Stopping server
[02:26:55] [Server Shutdown Thread/INFO]: Stopping server
eula=trueas a single line. Re-ran the Minecraft_server.jar and it started fine.
[02:40:13] [User Authenticator #1/INFO]: Disconnecting com.mojang.authlib.GameProfile@XYZXYZ[id=<null>,name=XYZXYZ,properties={},legacy=false] (/192.168.88.108:51300): Authentication servers are down. Please try again later, sorry!
[02:40:13] [User Authenticator #1/ERROR]: Couldn't verify username because servers are unavailable
[02:40:13] [Server thread/INFO]: com.mojang.authlib.GameProfile@XYZXYZ[id=<null>,name=XYZXYZ,properties={},legacy=false] (/192.168.88.108:51300) lost connection: Authentication servers are down. Please try again later, sorry!
