sorcimatt
Oct 31, 2011Aspirant
Mirrored HD from ReadyNads Duo to ReadyNas Nv+ (#17049293)
Hi. I have a ReadyNas Duo that is completely dead and I have probably the RAID 0 HD that has some problem as well. I have just received one brand new ReadyNas NV+ with a couple of HDs. I have to bo...
arjoseph1
Nov 01, 2011Tutor
If you are trying to recover the data, I will recommend that you contact support. But if not, them you may just perform a factory reset. Please also append the case # that you will get from a support rep to the subject of your post.
