sorcimatt
Oct 31, 2011Aspirant
Mirrored HD from ReadyNads Duo to ReadyNas Nv+ (#17049293)
Hi. I have a ReadyNas Duo that is completely dead and I have probably the RAID 0 HD that has some problem as well. I have just received one brand new ReadyNas NV+ with a couple of HDs. I have to bo...
Thomas_xh1
Nov 10, 2011Tutor
It is beeter to start you NV+ with only original disk 2, the system should be start if the the disk has no issue.
Then hot-add a new brand disk to redundance it. but I did not suggest you to do that.
It is better to start the NV+ with original disk 2, then backup all of it data.
then factory default all of you NV+ with all disks, because the ReadyNAS Duo only worked with Raid-1 for volume data. and the NV+ X_RAID work in Raid_5.
