slimpig
Mar 08, 2011Follower
missing files and folders when streaming
I'm playing back video and music through my WDTVLive, when I first got the ReadNAS duo, everything worked ok. But as soon as I put on the firmware update half of my files and folders are missing when ...
klockareson
Aug 25, 2011Aspirant
dang0404 wrote: Hi All, i have the same issue, dont believe any update has happened. I run a WDTV live and a ReadyNAS NV+, but the WD only see's like 2 or 3 folders and not 5 or 6 like it should.
I have been working on this for a while and cant seem to come up with a solution. Had a look through these forums and couldn't see anyone else have a definite solution either.
Is there someone to contact about this issue as it was working fine for months then just started doing this.
Any advice would be appreciated.
Cheers
Dan
Same issue here. I run PS3, TVIX 7000 and ReadyNAS Duo...Only a brink of the folders are shown and also...When I try to rescan for new mediafiles, the button is greyed out.
Anyone got a clue here?
Jeppe
