slimpig
Mar 08, 2011Follower
missing files and folders when streaming
I'm playing back video and music through my WDTVLive, when I first got the ReadNAS duo, everything worked ok. But as soon as I put on the firmware update half of my files and folders are missing when ...
dillyhammer
Sep 04, 2011Aspirant
I've reinstalled TwonkyServer and purchased a license - about $21CAD. It's a bit of a bugger setting it up, but once that's done it does not have the folder problem live ReadyDLNA does - everything scans up just fine and it's pretty damn quick about it too.
Some notes for those who care to go this route, as a fix for the scanner issue doesn't seem imminent.
You'll need to install the enable-root-ssh add-on and ssh into your device. I have a share called "videos" with a folder called "videos" in it where all my stuff is stored. I was unable to get Twonky to scan that folder as it auto-prepends /c/media to any entry in the shares you add to the config interface. What I did was add a symlink in /c/media to /videos/videos and away it went.
Also, if you have very large files you may want to edit the Twonky config file. There's a setting there for the maximum scan time per file, which is defaulted to 30 (seconds). I've upped that to 120 and it seemed to have smoothed over the scans of my larger mkv files.
The config file is located at /var/twonkymedia/twonkymedia/twonkymedia-server.ini. You'll have to use vi, google for a vi cheat sheet if you're not familiar with it. A little painful, this whole process.
I've left ReadyDNLA disabled because it's useless.
Shame I had to spend $20+ to correct this, but what the heck. I needed a solution.
There you have it.
Mike
There you have it.
Mike
