slimpig
Mar 08, 2011Follower
missing files and folders when streaming
I'm playing back video and music through my WDTVLive, when I first got the ReadNAS duo, everything worked ok. But as soon as I put on the firmware update half of my files and folders are missing when ...
tainin
Mar 30, 2012Aspirant
Hello everyone, hola a todos.
I have the same problem, for more than a year I used my ReadyNAS DUO with my Samsung TV 46C8000 and has always worked perfectly.
He had two hard drives configured with 2 TB XRAID (redundant), but to save space on the disks, after saving all my data, switch to Flex-RAID (RAID 0).
Since then not get it to work properly DLNA. The TV only recognizes one of the folders that exist in the folder "media", even though I upgraded to version v1.0.24 ReadyDLNA.
Also a very curious thing happens, but I only see a folder, if renamed from Windows any of the folders then whether to recognize the TV, but turn off READYNAS returning only recognizes one again.
No solution from netgear.
Do you know other NAS works well with DLNA??
Thank you.
Thank you.
