rlyon
Feb 26, 2012Aspirant
Missing files/folders
I had the NV+ working perfectly with my new WDTV Live. So I added more movie files (mkvs) and I cleaned up my NAS by deleting some old movies as well. However, the WDTV Live did not see the new movies...
rlyon
K, I updated and that did nothing. However, I had a few different folders with movies that I had recently moved onto the NAS. So I moved a chunk of them into a 'videos' folder. Since I did that, the folders before that one now display and the videos in those folders display and play. So I think I have a bad file, or it's because I have files not inside folders.
So I will put all the strays into a folder to see if that helps, otherwise, i believe it to be a bad file. How do I check for a bad movie file when they are all 3gb-15gb in size? I will go by a date created sort, and try to move those into a newly created folder, and them move them out one by one I guess.
