rlyon
Feb 26, 2012Aspirant
Missing files/folders
I had the NV+ working perfectly with my new WDTV Live. So I added more movie files (mkvs) and I cleaned up my NAS by deleting some old movies as well. However, the WDTV Live did not see the new movies...
rlyon
OK, well, I thought it was a bad file. So I made a new folder, put in the good ones, and I only added 3 movies to the new folder, so nothing of any value. I went and check the WDTV and it showed all of my folders and all the content in all of the folders. So maybe readydlna did work and my NV+ just needed time to re-scan and update the wdtv live?
Either way, whoohoo.
*Edit, so it has everything up to a certain movie alphabetized with P, then doesn't display about 15 movie folders/files after through z (but does now show every folder). So not sure if the scanning didn't finish or if the WDTV Live simply hasn't updated all the files. I just deleted one file off the NV+ and it still shows on the Live. Is there a general procedure for getting the media player to update to get the latest files? Like it's caching or something.
