Paul-PMC
Nov 24, 2015Aspirant
More shares exists than created during NAS setup
Dear Community, I had to re-install my ReadyNASRND2000 because both hard disks (3,5'' - 1 TB) has noticed more and more errors in the last month. The shop person where I bought the NAS (Media Mar...
- Dec 02, 2015
Dear StephenB,
thank you for all your help. It was great.
regs. Paul
Nov 24, 2015Guru - Experienced User
- \\NAS-D0-0A-CA\c is the data volume, and if you delete it you lose all all your data.
- \\NAS-D0-0A-CA\home is a "private home share" feature.
- \\NAS-D0-0A-CA\admin another path to \\NAS-D0-0A-CA\home\admin
Don't delete home (or \admin). If you don't want the private home share feature, then you can disable it with frontview.
Select security->user & group accounts
Then select "preferences" in the pulldown on the upper right.
You'll see the "Private home shares for users" option - it should be second on the list.
The feature is described on page 31 here: http://www.readynas.com/download/documentation/UM/RAIDiator4-1_SW_en_30Nov11.pdf
- Paul-PMCDec 02, 2015Aspirant
Dear StephenB,
regs. Paul
