rbng
Jan 20, 2019Follower
Mount ReadyNAS USB Drive on Mac
I have a USB drive connected to my ReadyNAS which I used the ReadyNAS to format. I tried several formats Ext3, Ext4, ... I am able to fully access the USB drive using the ReadNAS web interface.
Jan 21, 2019Guru - Experienced User
Well, ext formats are linux-only. Since you have NTFS support on the Mac, then you should be formatting the drive as NTFS.
You can do that in the NAS or in the PC.
