n_damian
Dec 06, 2015Aspirant
Mount/access encrypted volume
Hello
How to mount/access encrypted volume after reset the ReadyNAS to factory default? Before reset the ReadyNAS to factory default the encrypted disk was removed. After reset encrypted disk in gui is red.
Power down, remove all disks (label order). Put just the encrypted disk in the NAS (same slot as before), connect the USB key and power on.
- mdgm-ntgrNETGEAR Employee Retired
- n_damianAspirant
Whether the disk encrypted on Readynas 104 (6.4.1) is compatible with Readynas 104 (6.4.1) or Readynas Ultra 2 (6.4.1).
Can I put disk encrypted on Readynas 104 into Readynas 102 (or Readynas Ultra 2).
