jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
mdgm-ntgr
Jul 23, 2012NETGEAR Employee Retired
You should be able to use it fully with ML already. Just the client apps I mentioned (RAIDar for Mac and ReadyNAS Remote for Mac), I think aren't Gatekeeper signed yet. So if you wanted to install these after updating to ML you'd have to change the security settings to accept installing apps that aren't Gatekeeper signed.
I don't think there's a major change to AFP requirements to put the spanner in the works like there was with Lion.
NetGear is a customer of NetAFP which develops the Netatalk project and the AFP support is very good.
