jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
Josc73
Aug 04, 2012Aspirant
Hi there!
Upgraded my Mac's to ML and guess what? No luck with Time Machine anymore... I've been reading on this forum and tried the following:
1. Restarted the ReadyNAS
2. Restarted my Mac with Time Machine off and then re-initiated it after restart
3. Upgraded the Duo to 4.1.10-T3
4. Double checked that AFP advertises over Bonjour.
The strange thing here is that I can get it to backup once if I disable AFP and the reenable it. Then it will backup, although very slow. Takes about 2 minutes in the state "Looking for backup disk" and then it gets going. If I try to make a new backup directly it will not work. Also my shares (AFP) has disappeared. It is almost as Time Machine disables the share in the clean-up phase?
Anyone else experienced the same?
/Joakim
/Joakim
