jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
NerdyMike
Aug 20, 2012Aspirant
@Chewbacca - I've tried connecting via the GUI (nfs://IP.Of.Netgear.ReadyNas) and via command line. I get the useless error of "can't find share" - but I'm not onsite for the specific wording right now.
Before my server upgrade from 10.6.8 to 10.8 it worked fine, after no nfs or rsync (I use a script that runs rsync and it fails with the same message).
I did have the share restricted to just the server IP (which I checked & double checked) and then I turned that off and "default read/write" access on.
I can see the share is published OK from the 10.8 server but can't access it via either. (other protocols like AFP are not turned on due to the old file name bug to do with direct RSync backups from HFS+ volumes...)
I can head back onsite for further testing if you want me to look into anything.
