jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
Josc73
Aug 31, 2012Aspirant
Still having problem with my ReadyNAS Duo and ML...
If I disable AFP under standard file protocols and directly re-enable it will work once:
No problems there right? Well, next backup generates this:
Why can it work only once?? I have searched and searched but it seems like no one else has this problem after upgrading to ML. I have two different Mac's at home and both behaves the same after the upgrade...
Starting manual backup
Attempting to mount network destination URL: afp://ReadyNAS@nasse.local/ReadyNAS
Mounted network destination at mount point: /Volumes/ReadyNAS using URL: afp://ReadyNAS@nasse.local/ReadyNAS
Disk image /Volumes/ReadyNAS/JockesMBP.sparsebundle mounted at: /Volumes/Time Machine Backups
Backing up to: /Volumes/Time Machine Backups/Backups.backupdb
Using file event preflight for Macintosh HD
Will copy (752.2 MB) from Macintosh HD
Found 23513 files (1.27 GB) needing backup
2.9 GB required (including padding), 312.82 GB available
Copied 31698 files (1.02 GB) from volume Macintosh HD.
Will copy (122.1 MB) from Macintosh HD
Found 993 files (122.1 MB) needing backup
1.53 GB required (including padding), 311.61 GB available
Copied 2723 files (145.3 MB) from volume Macintosh HD.
Created new backup: 2012-08-31-090343
Starting post-backup thinning
No post-back up thinning needed: no expired backups exist
Backup completed successfully.
Ejected Time Machine disk image: /Volumes/ReadyNAS/JockesMBP.sparsebundle
Ejected Time Machine network volume.
Backup failed with error: 19
