jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
mchards
Sep 09, 2012Aspirant
Well, the Login Window/user switch unmount behavior is pretty consistent. Interestingly, sleeping (without going to the Login Window) does result in a reconnection to the share after a couple of failed attempts:
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect started /Volumes/media prevTrigger 0 currTrigger 1
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: doing reconnect on /Volumes/media
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: posting to KEA EINPROGRESS for /Volumes/media
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: Max reconnect time: 30 secs, Connect timeout: 15 secs for /Volumes/media
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: connect to the server /Volumes/media
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: connect on /Volumes/media failed 49.
9/9/12 5:29:37.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: sleep for 1 seconds and then try again
9/9/12 5:29:38.303 PM com.apple.backupd-helper[85431]: Not starting Time Machine backup after wake - less than 60 minutes since last backup completed.
9/9/12 5:29:38.478 PM ntpd[84088]: ntpd exiting on signal 1
9/9/12 5:29:38.566 PM configd[17]: network changed: v4(en0-:192.168.0.2) DNS- Proxy- SMB-
9/9/12 5:29:38.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: connect to the server /Volumes/media
9/9/12 5:29:38.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: connect on /Volumes/media failed 65.
9/9/12 5:29:38.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: sleep for 2 seconds and then try again
9/9/12 5:29:38.967 PM configd[17]: network changed: v4(en0+:192.168.0.2) DNS+ Proxy+ SMB+
9/9/12 5:29:38.511 PM KernelEventAgent[63]: tid 00000000 received event(s) VQ_NOTRESP (1)
9/9/12 5:29:39.250 PM KernelEventAgent[63]: tid 00000000 type 'afpfs', mounted on '/Volumes/media', from '//[xxxx@yyyy]_afpovertcp._tcp.local/media', not responding
9/9/12 5:29:40.999 PM KernelEventAgent[63]: tid 00000000 found 1 filesystem(s) with problem(s)
9/9/12 5:29:40.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: connect to the server /Volumes/media
9/9/12 5:29:40.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: Logging in with uam 8 /Volumes/media
9/9/12 5:29:41.865 PM KernelEventAgent[63]: tid 00000000 received event(s) VQ_NOTRESP (1)
9/9/12 5:29:41.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: Restoring session /Volumes/media
9/9/12 5:29:41.000 PM kernel[0]: AFP_VFS afpfs_DoReconnect: get the reconnect token
It's interesting that the wired Ethernet connection seems to go down then back up while resuming from sleep. FWIW, I did a clean ML install and brought my files and stuff over via Migration Assistant as that seemed to be the common advice for updating from Snow Leopard to Lion.
