jonsenge
Jul 23, 2012Aspirant
Mountain Lion Compatibility
Is there any early word on Mountain Lion compatibility for the ReadyNAS models?
mdgm-ntgr
Sep 21, 2012NETGEAR Employee Retired
If things are working fine for you on 4.1.8 then it'd be fine to stick with that for now. The ownership issue was fixed in the 4.1.10 betas and remains fixed. 4.1.10 should perform better than 4.1.8 and has updated AFP/Time Machine support compared with 4.1.8.
If you're having issues on old firmware I'd definitely recommend giving the update a try.
