PredatorVI's avatar
Jun 06, 2017
Move existing drives from RNDP6000 to RNDP600E ... is it possible?
My ReadyNAS Pro 6 (RNDP6000v2) power supply bit the dust.  They are sending me a newer unit via RMA but the OS and X-RAID configuration won't be compatible with the old drives.  There may be a data r...
  • StephenB's avatar
    Jun 07, 2017
    What NAS model are they sending you?
    PredatorVI wrote:
    I am looking to see if I could put the old drives in a functioning RNDP600E in a way that will allow me to mount the XRaid volume and transfer the data off to the new unit intact.
    That works, though it'd be good to put the same firmware on the 600E before you do it.  If you skip this step, the system will update the OS on the disks to match whatever is in the flash.  That often has no bad effects, but if the firmware is very mismatched it can cause problems.
    If there are no drives in the 600E, you can temporarily install a scratch disk, then match the firmeware.  If you aren't sure what you were running in the pro, then install the latest firmware (4.2.31).
ProSupport for Business
