edkedk
Dec 14, 2016Tutor
Move HDDs from dead NV+ to another?
Hi,
We have a ReadyNAS NV+ (RND4000 v3) that suddenly died. Does not power up. We also have another NV+ (RND4250) that is not in active use. The 4250 has RAIDiator 4.1.7 [1.00a043], the 4000's fw version is unknown.
Can I simply move the HDDs from the dead NAS to the other and not lose data?
edkedk wrote:
I don't know the fw version on the dead unit.
Should I do anything on the working unit before removing the disks and putting in the ones from the dead unit?
I'd install 4.1.15.
edkedk wrote:
Are settings like IP address, defined shares etc. going to be inherited as disks are transferred?
Yes. All the settings are kept on the disks themselves.
That will work, but if the firmware on the spare isn't 4.1.7 then 4.1.7 will be installed onto the disks.
So you might want to install a scratch disk on the spare first, and install the firmware you want there.
- edkedkTutor
Thank you.
For example delete existing shares, resetting all settings...?
I'd install 4.1.15.
