plusterkopp's avatar
Mar 30, 2018
Move /home to another volume
I used to have two JBOD disks, one 3TB and one 4TB. The first one had /home mounted. I removed the 3TB to make room for a new 8TB disk. Copied files from the 4TB disk to the new one. Then put the 3TB back in, copied more files to the 8TB disk. Also I copied /home to a backup folder on 8TB. Since I want to continue using the 4TB disk alongside 8TB, the 3TB will stay out.
Now, ReadyNAS Admin GUI shows the Home Folder as residing on the 4TB disk (but empty), which is OK with me. However, the system does not mount /home from 4TB but instead from /dev/md0.
The Admin pages provide no option to assign the Home folder to a disk, but as I said, when it says Home is on 4TB, this would be fine. Now why does the box not mount home from 4TB on startup? Is there any other setting in some config file that I must alter? Or is the GUI not consistent with some entry in readynasd Database?
What can I do here?
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    There are systemd mount files for homes and apps. The path to mount is specified inside these files. You may need to manually update these.
    Also check /etc/fstab to make sure the old volume isn’t still mentioned in that.
    • plusterkopp's avatar
      plusterkopp
      Tutor
      thanks a lot, the systemd config change did it. Alhough the question remains why this isn't reflected in the web gui. But then I am still using 6.8.1.
        plusterkopp
        Tutor
        while the system works now unsing SMB and other services, I can no longer use the admin page. Browser tells me it's offline, after logging in and overriding the browser's certificate panic.
        Readynasd seems to have issues starting up properly:
        systemctl status readynasd
        ● readynasd.service - ReadyNAS System Daemon
           Loaded: loaded (/lib/systemd/system/readynasd.service; enabled; vendor preset: enabled)
           Active: failed (Result: start-limit-hit) since Sun 2018-04-15 00:35:55 CEST; 14min ago
          Process: 6828 ExecStart=/usr/sbin/readynasd -v 3 -t (code=exited, status=255)
         Main PID: 6828 (code=exited, status=255)
           Status: "Importing DB"
        Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Unit entered failed state.
        Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Failed with result 'exit-code'.
        Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Service hold-off time over, scheduling restart.
        Apr 15 00:35:55 BingNAS systemd[1]: Stopped ReadyNAS System Daemon.
        Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Start request repeated too quickly.
        Apr 15 00:35:55 BingNAS systemd[1]: Failed to start ReadyNAS System Daemon.
        Apr 15 00:35:55 BingNAS systemd[1]: readynasd.service: Failed with result 'start-limit-hit'.
        Is there any other config file that must be modified?
ProSupport for Business
