rclementtx
May 09, 2016Guide
Moving complete volume from RN314 to RN316
This may be obvoius to the experienced user, but wanted a "gut check" before I jump off the deep end. I have a relatively new RN314 with 3 of 4 disk slots filled. Operating in X-Raid. I like the h...
- May 10, 2016
If you are moving all the disks across and those will be the only disks in the new NAS then you don't need to use the export volume feature at all.
mdgm-ntgr
May 09, 2016NETGEAR Employee Retired
All you need to do is:
1. Power down both systems
2. Remove disks (label order)
3. Move the 3 disks across keeping the order the same (make sure they are the only disks in the new NAS)
4. Power on.
- rclementtxMay 09, 2016Guide
Many thanks. When does "exporting" come into play?
- mdgm-ntgrMay 10, 2016NETGEAR Employee Retired
- rclementtxMay 10, 2016Guide
Installed all disks from 314 to 316. Worked fine. No issues apparent. I think this concern is closed.
