kelvin33's avatar
kelvin33
Moving complete volume from RN316 to RN316
HI,   I have acquired another RN316(B), the exisiting RN316(A) has 6 (6TB) in there where on of the disk is dead. Can I move the balance 5 disk to the new system in the actual order w/o the dead di...
  • StephenB's avatar
    Jul 08, 2016
    You can migrate, but you will need to destroy the data volume and recreate it.  It probably doesn't matter which system you do that on.
    If you don't have a lot of user accounts, you might as well start clean with a factory default.  Any apps likely are no longer functional anyway since the data volume isn't there.
ProSupport for Business
