ukbobboy's avatar
ukbobboy
Luminary
Feb 12, 2016
MP4 and MKV files
Dear Forum Members & Seniors   I have Plex installed on my RN Duo v2, which cannot transcode, and I can play MP4 films and TV shows directly to my TV, via my Now TV smart box.  Since I found out th...
  • StephenB's avatar
    Feb 12, 2016
    @ukbobboy1 wrote:
    But now, I see that I may soon have to try and use MKV files, so my question is this: Can I direct play MKV files without the need for transcoding just like I can now play MP4 files?
    It depends on the player's capabilities and the audio/video codecs used in the MKV.  If for instance, the MKV uses DTS audio, and the player doesn't support DTS, then it won't play.
ProSupport for Business
