DanielPL
Aug 08, 2018Aspirant
Multi accounts for one device
This is my first post, so I want to say hello.
I use the ReadyNas102 device. I know that it is a bit old, but it works and I have no objections to its work.
I came across a problem that I...
Aug 09, 2018Guru - Experienced User
DanielPL wrote:
I can not backup everything on one folder because users can not see each other's folders.
Are you asking how to backup the user backups? I believe they are all stored in home folder, which you can select as a backup source in a ReadyNAS backup job.
Or do you wanting multiway sync? ReadyCloud won't do that, you'll need to use something else.
- DanielPLAug 21, 2018Aspirant
Hey!
The solution to share the directory with other readycloud users works - the problem has been resolved. Almost...
There were two more problems.
The first one is the speed of data transfer, upload to ReadyNas. I tested on several links and unfortunately it is always up to 5-6 Mb / s. Do you limit the transfer speed in some way?
The second problem is the suspension of the service - this is how it looks on my side. New files appear in the folder (backup of databases in the size of about 2GB). Unfortunately, they are not sent to ReadyNas. I see that the task is at the stage of synchronizing or indexing the content. It stops at this. No error appears. The indexing or sync indicator is simply displayed at 0%.
Firewall disabled, successfully pinging to the address of the VPN.
Can you help me with this?
Thanks!
- DanielPLSep 06, 2018Aspirant
Hey!
Does anyone of you know the way to solve this issue?
I also have a problem with starting the service, synchronization sometimes stops. Is it possible to resume it somehow from the command line or windows task scheduler?
Best Regards!
- Apr 16, 2020Retired_Member
