DanielPL
Aug 08, 2018Aspirant
Multi accounts for one device
This is my first post, so I want to say hello.
I use the ReadyNas102 device. I know that it is a bit old, but it works and I have no objections to its work.
I came across a problem that I...
Aug 09, 2018Guru - Experienced User
DanielPL wrote:
I can not backup everything on one folder because users can not see each other's folders.
Are you asking how to backup the user backups? I believe they are all stored in home folder, which you can select as a backup source in a ReadyNAS backup job.
Or do you wanting multiway sync? ReadyCloud won't do that, you'll need to use something else.
DanielPL
Aug 21, 2018Aspirant
Hey!
The solution to share the directory with other readycloud users works - the problem has been resolved. Almost...
There were two more problems.
The first one is the speed of data transfer, upload to ReadyNas. I tested on several links and unfortunately it is always up to 5-6 Mb / s. Do you limit the transfer speed in some way?
The second problem is the suspension of the service - this is how it looks on my side. New files appear in the folder (backup of databases in the size of about 2GB). Unfortunately, they are not sent to ReadyNas. I see that the task is at the stage of synchronizing or indexing the content. It stops at this. No error appears. The indexing or sync indicator is simply displayed at 0%.
Firewall disabled, successfully pinging to the address of the VPN.
Can you help me with this?
Thanks!
- DanielPLSep 06, 2018Aspirant
Hey!
Does anyone of you know the way to solve this issue?
I also have a problem with starting the service, synchronization sometimes stops. Is it possible to resume it somehow from the command line or windows task scheduler?
Best Regards!
- Apr 16, 2020Retired_Member
