ImmyB
Jan 23, 2017Aspirant
Multiple IP Addresses
Hello community, I've been using a ReadyNAS Pro 6 for a very very long time and over the years not really bothered much with it's configuration as it was mainly used as a storage dump however unl...
ImmyB
Jan 25, 2017Aspirant
If anyone was wondering you can 'manually' add as many IPs as you want, however they only remain accessible until the server/nas is rebooted at which point they get removed and you have to re-enter the command. I'm sure a script could be made to do this on boot but I'm not sure which files are executed on boot, unless someone can point me in the right direction, thanks.
- evan2Feb 02, 2017NETGEAR Expert
Hi ImmyB,
Did you set VLAN on switch?
Please note: VNIC can't be in the same subnet as the Physical Ethernet Interface.
In switch, all ports have default PVID,
if create VLAN on switch, VLAN ID should be different from PVID,
In NAS, Phyiscal Ethernet interface and VNIC use same MAC, if PVID and VLAN ID are same, Physical Ethernet interface and VNIC will get same IP address.
for example: Default PVID is 1, VLAN ID can't be set to 1,
