rantech
Jun 13, 2017Aspirant
Multiple simultaneous RSYNC Jobs
I'm wondering how a 316 would react to having to different remote units trying to run remote RSYNC backup jobs into or out of the 316 at the same time. If all RSYNC jobs are initiated on the same ma...
Jun 14, 2017Guru - Experienced User
rantech wrote:
is OS 6 smart enough to put one of the jobs on hold until it has finished responding to the other ?
No. The jobs will just run in parallel (along with any other user access).
I don't think that was the cause of your NVX failure.
rantech
Jun 14, 2017Aspirant
As it turns out, I have a few different UPS units on different devices. My "expensive" pure sine wave UPS reports electrical noise and switching over to battery at the time that the NVX died. The NVX was connected to a cheaper not pure sine wave UPS in the same location and that UPS does not report any electrical problems or having switched over to battery at the time that the NVX died ... it would appear likely that electrical noise cratered the UPS ... so much for "cheap" UPS units as none of my less expensive units are reporting any of the power events that my expensive unit is reporting (4 events in the last 24 weeks) ...
