Andrenalin
Sep 17, 2014Aspirant
My Device is Offline again :(
Hello i am not sure if this is the right place to post this, but my readynas 102 has the device is offline issue again.... This time because there was a power blackout. I tried phone support, but i...
xeltros
Sep 17, 2014Apprentice
Ok, so summary :
- Device works except the GUI
- SSH was enabled but never used (by you anyway)
- You already had the problem and support solved it
- OS reinstall or reboot do not solve the problem
- from what you've shown the / partition still has room, and the web server is running fine...
- only addon installed was plex
Did you try both http://ip and https://ip ? does https://ip/admin works ? Do you have something on screen or is it the browser default page for unavailable resource ?
Depending on that it may be the rights on the files, perhaps...
To be honest I am exhausting my options here, I'll try to find other things to test but you may want to create a case via mail and ask them to solve it AND tell you how they did it. If you ask nicely I'm sure they will tell you what was wrong and which commands they used.
Also I would backup the data while it is accessible (it should already have been done). It is possible that a factory default would solve this definitively.
