Andrenalin
Sep 17, 2014Aspirant
My Device is Offline again :(
Hello i am not sure if this is the right place to post this, but my readynas 102 has the device is offline issue again.... This time because there was a power blackout. I tried phone support, but i...
mdgm-ntgr
Sep 18, 2014NETGEAR Employee Retired
You need to enter the command without the #. If you put the # at the start then it treats it as a comment, hence no output.
The output may help. Please also check the output of the command I mentioned in the PM.
