Andrenalin
Sep 17, 2014Aspirant
My Device is Offline again :(
Hello i am not sure if this is the right place to post this,
but my readynas 102 has the device is offline issue again.... This time because there was a power blackout. I tried phone support, but i have no longer phone support so their only tip is to do the os reinstall or try another browser. Is there anyway that i can repair this issue my self, so i have not to bother a forum member to help me everytime that happens? I can Access via ssh and raidar looks fine as well and i can access via network. It is only the web interface that does not work.
I am not very happy with my device because i run into that issue some times before, so i would appreciate every tip how i can deal with this issue by my self.
Thank you a lot!
Andrenalin
Thank you a lot!
Andrenalin
- AndrenalinAspirantOh Plex is no longer installed? How could that happen?
EDIT: Ups it was just disabled^^ - xeltrosApprenticeNone of my commands could have made the NAS come back online. They all appeared normal by the way.
- mdgm-ntgrNETGEAR Employee RetiredIf you get the "Device is Offline" error then apache is running, but readynasd is likely not.
- AndrenalinAspirantOK. It seems that after I typed service ctscand stop. The problem appeared solved. Could that be? The device went offline and restarted fine afterwards
Sent from my Lumia 710 using Tapatalk - AndrenalinAspirantMdgm yes after restart your command prompt worked fine so readynasd was nit running before. Don't know. But I am glad that you guys helped me out again. Thank you a lot. Much better than phone support ;).
