kema
Aug 12, 2011Aspirant
My NAS Duo is stuck, slow or dead!
Hi again. Suddenly my NAS is running very, very slow. Just to open it frontview takes 5 min, and maybe a hold 15 min to navigate to where I can shut it down. To copy 4gb to my pc would take 12 hours, ...
kema
I just took a little bite of my system log. maybe it means something for someone.
Aug 10 18:44:57 Basserne kernel: padre_power_down_task
Aug 10 21:38:19 Basserne syslogd 1.4.1#10: restart.
Aug 10 21:38:19 Basserne kernel: klogd 1.4.1#10, log source = /proc/kmsg started.
Aug 10 21:38:19 Basserne kernel: Linux version 2.6.17.14ReadyNAS (root@calzone) (gcc version 3.3.5 (Infrant 3.3.5-1)) #1 Wed Sep 22 04:42:09 PDT 2010
Aug 10 21:38:19 Basserne kernel: You system is PZERO.
Aug 10 21:38:19 Basserne kernel: ASIC=IT3107
Aug 10 21:38:19 Basserne kernel: On node 0 totalpages: 16384
Aug 10 21:38:19 Basserne kernel: Normal zone: 15360 pages, LIFO batch:3
Aug 10 21:38:19 Basserne kernel: DMA zone: 1024 pages, LIFO batch:0
Aug 10 21:38:19 Basserne kernel: zlist 0 802ef15c
Aug 10 21:38:19 Basserne kernel: zone 802eef14, name Normal
Aug 10 21:38:19 Basserne kernel: zlist 1 802ef170
Aug 10 21:38:19 Basserne kernel: zone 802eeccc, name DMA
Aug 10 21:38:19 Basserne kernel: zlist 2 802ef184
Aug 10 21:38:19 Basserne kernel: Built 1 zonelists
Aug 10 21:38:19 Basserne kernel: Kernel command line: root=/dev/ram0 init=/linuxrc rw raid=noautodetect profile=2
Aug 10 21:38:19 Basserne kernel: kernel profiling enabled (shift: 2)
Aug 10 21:38:19 Basserne kernel: PID hash table entries: 2048 (order: 11, 8192 bytes)
Aug 10 21:38:19 Basserne kernel: Dentry cache hash table entries: 32768 (order: 3, 131072 bytes)
Aug 10 21:38:19 Basserne kernel: Inode-cache hash table entries: 16384 (order: 2, 65536 bytes)
Aug 10 21:38:19 Basserne kernel: Memory: 226176k/262144k available (2592k kernel code, 35872k reserved, 656k data, 96k init, 0k highmem)
Aug 10 21:38:19 Basserne kernel: init_mm.pgd 8f0ff000
Aug 10 21:38:19 Basserne kernel: Calibrating delay loop... 186.36 BogoMIPS (lpj=931840)
Aug 10 21:38:19 Basserne kernel: Mount-cache hash table entries: 2048
Aug 10 21:38:19 Basserne kernel: checking if image is initramfs...it isn't (no cpio magic); looks like an initrd
Aug 10 21:38:19 Basserne kernel: Freeing initrd memory: 16384k freed
Aug 10 21:38:19 Basserne kernel: NET: Registered protocol family 16
Aug 10 21:38:19 Basserne kernel: usbcore: registered new driver usbfs
Aug 10 21:38:19 Basserne kernel: usbcore: registered new driver hub
Aug 10 21:38:19 Basserne kernel: NET: Registered protocol family 2
Aug 10 21:38:19 Basserne kernel: IP route cache hash table entries: 2048 (order: -1, 8192 bytes)
Aug 10 21:38:19 Basserne kernel: TCP established hash table entries: 8192 (order: 1, 32768 bytes)
Aug 10 21:38:19 Basserne kernel: TCP bind hash table entries: 4096 (order: 0, 16384 bytes)
Aug 10 21:38:19 Basserne kernel: TCP: Hash tables configured (established 8192 bind 4096)
Aug 10 21:38:19 Basserne kernel: TCP reno registered
Aug 10 21:38:19 Basserne kernel: audit: initializing netlink socket (disabled)
Aug 10 21:38:19 Basserne kernel: audit(1070280003.190:1): initialized
Aug 10 21:38:19 Basserne kernel: VFS: Disk quotas dquot_6.5.1
Aug 10 21:38:19 Basserne kernel: Dquot-cache hash table entries: 4096 (order 0, 16384 bytes)
Aug 10 21:38:19 Basserne kernel: Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
Aug 10 21:38:19 Basserne kernel: Initializing Cryptographic API
Aug 10 21:38:19 Basserne kernel: io scheduler noop registered
Aug 10 21:38:19 Basserne kernel: io scheduler anticipatory registered
Aug 10 21:38:19 Basserne kernel: io scheduler deadline registered
Aug 10 21:38:19 Basserne kernel: io scheduler cfq registered (default)
Aug 10 21:38:19 Basserne kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Aug 10 21:38:19 Basserne kernel: loop: loaded (max 8 devices)
Aug 10 21:38:19 Basserne kernel: nbd: registered device at major 43
Aug 10 21:38:19 Basserne kernel: tun: Universal TUN/TAP device driver, 1.6
Aug 10 21:38:19 Basserne kernel: tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
Aug 10 21:38:19 Basserne kernel: md: raid0 personality registered for level 0
Aug 10 21:38:19 Basserne kernel: md: raid1 personality registered for level 1
Aug 10 21:38:19 Basserne kernel: md: raid5 personality registered for level 5
Aug 10 21:38:19 Basserne kernel: md: raid4 personality registered for level 4
Aug 10 21:38:19 Basserne kernel: xor engine => SPARC.
Aug 10 21:38:19 Basserne kernel: device-mapper: 4.6.0-ioctl (2006-02-17) initialised: dm-devel@redhat.com
Aug 10 21:38:19 Basserne kernel: Serial: Padre driver $Revision: 1.1.1.1 $ 2 ports
Aug 10 21:38:19 Basserne kernel: ttyS0 at I/O 0x0 (irq = 7) is a padre uart
Aug 10 21:38:19 Basserne kernel: ttyS1 at I/O 0x0 (irq = 8) is a padre uart
Aug 10 21:38:19 Basserne kernel: oprofile: using timer interrupt.
Aug 10 21:38:19 Basserne kernel: TCP bic registered
Aug 10 21:38:19 Basserne kernel: NET: Registered protocol family 17
Aug 10 21:38:19 Basserne kernel: NET: Registered protocol family 5
Aug 10 21:38:19 Basserne kernel: 802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
Aug 10 21:38:19 Basserne kernel: All bugs added by David S. Miller <davem@redhat.com>
Aug 10 21:38:19 Basserne kernel: md: Skipping autodetection of RAID arrays. (raid=noautodetect)
Aug 10 21:38:19 Basserne kernel: RAMDISK: Compressed image found at block 0
Aug 10 21:38:19 Basserne kernel: VFS: Mounted root (ext2 filesystem).
Aug 10 21:38:19 Basserne kernel: Freeing unused kernel memory: 96k freed
Aug 10 21:38:19 Basserne kernel: padre_i2c: module license 'Infrant Technologies, Inc.' taints kernel.
Aug 10 21:38:19 Basserne kernel: padre_i2c: no version for "udiv" found: kernel tainted.
Aug 10 21:38:19 Basserne kernel: TWSI Initialize
Aug 10 21:38:19 Basserne kernel: Padre NSPIO setup: 80353394... No argv, go to default.
Aug 10 21:38:19 Basserne kernel: raid5: xor select to PADRE_RXA.
Aug 10 21:38:19 Basserne kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Aug 10 21:38:19 Basserne kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Aug 10 21:38:19 Basserne kernel: padre chip scan,token=1
Aug 10 21:38:19 Basserne kernel: Scan the padre NSP IO hardware.
Aug 10 21:38:19 Basserne kernel: Need memory for RTEngine 63680
Aug 10 21:38:19 Basserne kernel: PIO mode on chan 7
Aug 10 21:38:19 Basserne kernel: DMA mode on chan 0
Aug 10 21:38:19 Basserne kernel: DMA mode on chan 1
Aug 10 21:38:19 Basserne kernel: Padre IDE controller, sata start:1
Aug 10 21:38:19 Basserne kernel: WD drive does not support TLER, 0, 3730
Aug 10 21:38:19 Basserne kernel: hdc: WDC WD1002FAEX-00Z3A0 (s/n:WD-WCATR3984285), ATA DISK drive (ATAEXT)
Aug 10 21:38:19 Basserne kernel: No TLER on Hitachi HDT721010SLA360 ^P\200@
Aug 10 21:38:19 Basserne kernel: hde: Hitachi HDT721010SLA360 (s/n:STF607MH1J5VGW), ATA DISK drive (ATAEXT)
Aug 10 21:38:19 Basserne kernel: ide1 at 0x200-0x207,0x208 on irq 32
Aug 10 21:38:19 Basserne kernel: ide2 at 0x280-0x287,0x288 on irq 33
Aug 10 21:38:19 Basserne kernel: Update NSPIO settings 80353394.
Aug 10 21:38:19 Basserne kernel: hdc: max request size: 512KiB
Aug 10 21:38:19 Basserne kernel: hdc: use capacity 1953525168 sectors (1000204 MB)
Aug 10 21:38:19 Basserne kernel: Drive support hpa, still should not change max addr.
Aug 10 21:38:19 Basserne kernel: hdc: 1953108616 sectors (999991 MB), CHS=65535/255/63
Aug 10 21:38:19 Basserne kernel: hdc: cache flushes supported
Aug 10 21:38:19 Basserne kernel: hdc:chn=0, statu/LP_S=0x(d0/d050)29, 8
Aug 10 21:38:19 Basserne kernel: hdc1 hdc2 hdc3 < hdc5 >
Aug 10 21:38:19 Basserne kernel: hde: max request size: 512KiB
Aug 10 21:38:19 Basserne kernel: hde: use capacity 1953525168 sectors (1000204 MB)
Aug 10 21:38:19 Basserne kernel: hde: 1953108616 sectors (999991 MB) w/15001KiB Cache, CHS=65535/255/63
Aug 10 21:38:19 Basserne kernel: hde: cache flushes supported
Aug 10 21:38:19 Basserne kernel: hde:chn=1, statu/LP_S=0x(d0/d050)29, 8
Aug 10 21:38:19 Basserne kernel: unknown partition table
Aug 10 21:38:19 Basserne kernel: Link to padre IO.
Aug 10 21:38:19 Basserne kernel: RAID disks check:
Aug 10 21:38:19 Basserne kernel: ALL = 22/33/0/0/0/0/0/0, 2
Aug 10 21:38:19 Basserne kernel: IDE = 22/0/0/0/0/0/0/0, 1
Aug 10 21:38:19 Basserne kernel: MD = 0/0/0/0/0/0/0/0, 0
Aug 10 21:38:19 Basserne kernel: RAID rule check result: 0
Aug 10 21:38:19 Basserne kernel: md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
Aug 10 21:38:19 Basserne kernel: md: bitmap version 4.39
Aug 10 21:38:19 Basserne kernel: Disk protected mark = 1
Aug 10 21:38:19 Basserne kernel: x_raid_start: 1,current:0
Aug 10 21:38:19 Basserne kernel: BDL_count= 0, fw=SN04, model=
Aug 10 21:38:19 Basserne kernel: BDL_count= 1, fw=SN04, model=
Aug 10 21:38:19 Basserne kernel: GOT MEMORY FOR DJ: 128*4k
Aug 10 21:38:19 Basserne kernel: Drive hdc SB at 1953511632(-sbs) CURRENT
Aug 10 21:38:19 Basserne kernel: Drive hde SB at 1953511632(-sbs) CURRENT
Aug 10 21:38:19 Basserne kernel: x_raid_start: 1,result:0
Aug 10 21:38:19 Basserne kernel: Find PHY: 0
Aug 10 21:38:19 Basserne kernel: Lookup PHY ID: 0x0141, 0x0c
Aug 10 21:38:19 Basserne kernel: P0 GPIO initialization... BOARDID=1
Aug 10 21:38:19 Basserne kernel: Boot type/reason: normal/0/21028C7100789
Aug 10 21:38:19 Basserne kernel: Adjusting fan pwm................
Aug 10 21:38:19 Basserne kernel: I2C device 48 doesn't exist
Aug 10 21:38:19 Basserne kernel: I2C device 49 doesn't exist
Aug 10 21:38:19 Basserne kernel: I2C device 4a doesn't exist
Aug 10 21:38:19 Basserne kernel: I2C device 4b doesn't exist
Aug 10 21:38:19 Basserne kernel: The LM75 can not be found
Aug 10 21:38:19 Basserne kernel: NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Aug 10 21:38:19 Basserne kernel: Samsung NAND flash rev C
Aug 10 21:38:19 Basserne kernel: size of table 4096
Aug 10 21:38:19 Basserne kernel: table is there 0x8
Aug 10 21:38:19 Basserne kernel: bad block 2310 replacing by 4095
Aug 10 21:38:19 Basserne kernel: bad block 2314 replacing by 4094
Aug 10 21:38:19 Basserne kernel: bad block 2318 replacing by 4093
Aug 10 21:38:19 Basserne kernel: total bad block 3
Aug 10 21:38:19 Basserne kernel: bad 2310 = 4095 bad 2314 = 4094 bad 2318 = 4093 bad 4093 = -1 bad 4094 = -1 bad 4095 = -1 Total bad block number 3
Aug 10 21:38:19 Basserne kernel: retlen = 0x0200
Aug 10 21:38:19 Basserne kernel: VPD checksum = 0xcb1d
Aug 10 21:38:19 Basserne kernel: ECC is ON
Aug 10 21:38:19 Basserne kernel: Creating 2 MTD partitions on "NAND 64MiB 3,3V 8-bit":
Aug 10 21:38:19 Basserne kernel: 0x00000000-0x00100000 : "P0 flash partition 1"
Aug 10 21:38:19 Basserne kernel: 0x00100000-0x03ff4000 : "P0 flash partition 2"
Aug 10 21:38:19 Basserne kernel: NEON flash: probing 8-bit flash bus
Aug 10 21:38:19 Basserne kernel: CFI: Found no NEON flash device at location zero
Aug 10 21:38:19 Basserne kernel: NEON flash: unknown flash device, mfr id 0x1, dev id 0x0
Aug 10 21:38:19 Basserne kernel: NEON flash: Found no Atmel device at location zero
Aug 10 21:38:19 Basserne kernel: This board is not supported.
Aug 10 21:38:19 Basserne kernel: You can use parm_extport=X module parm.
Aug 10 21:38:19 Basserne kernel: I2C device 1f doesn't exist
Aug 10 21:38:19 Basserne kernel: I2C device 1b doesn't exist
Aug 10 21:38:19 Basserne kernel: LCD device not found
Aug 10 21:38:19 Basserne kernel: X_RAID_START
Aug 10 21:38:19 Basserne kernel: startstop XRAID command = start, flash_cache=0
Aug 10 21:38:19 Basserne kernel: X_RAID clean shutdown indicator: 0x3.
Aug 10 21:38:19 Basserne kernel: 0 2 2 0 0 0 0 0
Aug 10 21:38:20 Basserne kernel: 0 1 0 0
Aug 10 21:38:20 Basserne kernel: 1 0 0 0
Aug 10 21:38:20 Basserne kernel: 0 0 0 0
Aug 10 21:38:20 Basserne kernel: Update time for sb 1 = 4dfd0357.
Aug 10 21:38:20 Basserne kernel: Update time for sb 2 = 4dfd0357.
Aug 10 21:38:20 Basserne kernel: Update time for sb 3 = 0.
Aug 10 21:38:20 Basserne kernel: Update time for sb 4 = 0.
Aug 10 21:38:20 Basserne kernel: recent_ID = 1, select_ID=1, most_ID=2 right_mac=2
Aug 10 21:38:20 Basserne kernel: Selected sb 1, ctime=4dfd0357, id=3fb67861.
Aug 10 21:38:20 Basserne kernel: Use this image: 1
Aug 10 21:38:20 Basserne kernel: VERSION/ID : SB=(V:0.1.0) ID=<3fb67861.00000000.00000000.00000000> CT:4dfd0357
Aug 10 21:38:20 Basserne kernel: RAID_INFO : DISKS(TOTAL:2 RAID:2 PARITY:1 ONL:2 WRK:2 FAILED:0 SPARE:0 BASE:0)
Aug 10 21:38:20 Basserne kernel: SZ:1953108616 UT:00000000 STATE:0 LUNS:2 EXTCMD:1 LSZ:1953108614
Aug 10 21:38:20 Basserne kernel: LOGICAL_DRIVE : 0: B:0000000002 E:0004096000 R:1 O:1 I:1:000000000 DM:3
Aug 10 21:38:20 Basserne kernel: LOGICAL_DRIVE : 1: B:0004096002 E:1949012614 R:1 O:1 I:1:1578438658 DM:3
Aug 10 21:38:20 Basserne kernel: PHYSICAL_DRIVE: 0: DISK<N:0/1,hdc(22,0),ID:0,PT:1,SZ:1953108616,ST: B:online>
Aug 10 21:38:20 Basserne kernel: PHYSICAL_DRIVE: 1: DISK<N:1/2,hde(33,0),ID:1,PT:1,SZ:1953108616,ST:P :online>
Aug 10 21:38:20 Basserne kernel: CURRENT_DRIVE : DISK<N:0/1,XXX(22,0),ID:0,PT:1,SZ:1953108616,ST: B:online>
Aug 10 21:38:20 Basserne kernel: Need to do drives searching.
Aug 10 21:38:20 Basserne kernel: Find p d at 1, chn 1
Aug 10 21:38:20 Basserne kernel: Total=2; raid=2; ready=0; work=2; failed=0
Aug 10 21:38:20 Basserne kernel: Check degraded mode, start_pos=1
Aug 10 21:38:20 Basserne kernel: No drive missing, X_RAID run in opt mode.
Aug 10 21:38:20 Basserne kernel: Change X_RAID running mode from 0 to 1
Aug 10 21:38:20 Basserne kernel: Update backup SB.
Aug 10 21:38:20 Basserne kernel: X_RAID: recovery thread got woken up ...
Aug 10 21:38:20 Basserne kernel: New = 1, source drives = 3, current/active=2/2
Aug 10 21:38:20 Basserne kernel: hdc:chn=0, statu/LP_S=0x(d0/d050)29, 8
Aug 10 21:38:20 Basserne kernel: hdc1 hdc2 hdc3 < hdc5 >
Aug 10 21:38:20 Basserne kernel: hde: unknown partition table
Aug 10 21:38:20 Basserne kernel: chn=0, statu/LP_S=0x(d0/d050)29, 32
Aug 10 21:38:20 Basserne kernel: kjournald starting. Commit interval 5 seconds
Aug 10 21:38:20 Basserne kernel: EXT3 FS on hdc1, internal journal
Aug 10 21:38:20 Basserne kernel: EXT3-fs: recovery complete.
Aug 10 21:38:20 Basserne kernel: EXT3-fs: mounted filesystem with ordered data mode.
Aug 10 21:38:20 Basserne kernel: linked, 1000mbps mode
Aug 10 21:38:20 Basserne kernel: hdc: drive_cmd: status=0x51 { DriveReady SeekComplete Error }
Aug 10 21:38:20 Basserne kernel: hdc: drive_cmd: error=0x04 { DriveStatusError }
Aug 10 21:38:20 Basserne kernel: ide: failed opcode was: 0xef
