nbeglitis
Sep 29, 2013Aspirant
My NVX died
Hi, I had a small accident the other day. I shut down the NVX to re-arrange a few things in the room and when I attempted to power it up again I saw some sparks coming out and then the unit died. T...
mdgm-ntgr
Sep 29, 2013NETGEAR Employee Retired
You can migrate to those units but first put a spare disk (must not be from your array) in the replacement unit, update the firmware to at least as new as what you were running on the NVX, verify the update is successful, then power down and remove the spare disk.
I think your binaries will probably just work though you might find you need to recompile a few things.
The PSU might have failed. Open up the unit and check if you want. I think a replacement PSU would need to be rewire though (not sure about the NVX, there might be a thread on it).
