nbeglitis
Sep 29, 2013Aspirant
My NVX died
Hi, I had a small accident the other day. I shut down the NVX to re-arrange a few things in the room and when I attempted to power it up again I saw some sparks coming out and then the unit died. T...
fastfwd
Oct 17, 2013Virtuoso
nbeglitis wrote: If the fan sucks air in then it is kinda pointless because the exhaust vent in the NAS is probably the space between the disks and the front door.
Maybe. Or the underside of the NAS might be vented.
nbeglitis wrote: I will probably take the fan out and replace it with a Noctua.
If your power supply's fan is 40mm diameter, it's probably 20mm thick. Noctua fans are really nice, but as far as I know, they only sell one 40mm fan and it's only 10mm thick... So it will fit, and you'll certainly be able to make it quieter than the current fan, but it might not cool as well. Still, it'll probably cool better than no fan at all.
