BeeThalin's avatar
BeeThalin
Follower
Dec 21, 2020
My ReadyNAS NV+ is not showing in my maps.
I have a new computer (pc windows 10) and when I connect my My ReadyNAS NV+ it is  not showing in my maps. I have connected it via a Netgeard router and it worked fine on my old computer, also pc windows 10.  RAIDar has found it but I don't see it in my networks maps. How to do?
Thanks in advance,
Bee
1 Reply
  • StephenB's avatar
    You will need to enable the SMB 1 client on the new PC (go into "turn windows features on or off" to do that).
    Also, if you entered a credential for the NAS on the other PC, then you should enter that credential (or one for a different user perhaps) on the new PC.
    Then see if you can access the shares by entering \\nas-ip-address in the file explorer address bar (using the real IP address of course).  Be careful to use the correct slash.
ProSupport for Business
