debumitra
Mar 22, 2020Tutor
Name a USB Drive - not working
I recently updated the OS to 6.9.6 which is the Long-Term-Support version of 6.10.2. The release notes of 6.10.2 say that "USB Label can be set when formatting USB". But I was unable to set the label...
debumitra
Mar 23, 2020Tutor
I never updated to 6.10.2 as it was not an LTS release. I went straight from 6.9.5 Hotfix 1 to 6.9.6. I have two ReadyNAS hardware (RN314 and RN424). Both running 6.9.6 and both were updated straight from 6.9.5 Hotfix 1 to 6.9.6.
It seems that the fix was not included in 6.9.6.
I won't like to experiment with 6.10.2. I waited so long for the 6.9.6 LTS to come out. These are my production boxes; I rely on them heavily.
Isn't there another way?
Thanks you.
Sandshark
Mar 23, 2020Sensei
You clearly don't understand how the LTS and Stable versioning works. 6.9.6 would not be derived from 6.10.2, it would be derived from 6.9.5. 6.10.3 is derived from 6.10.2. So your expectation that a change made in 6.10.2 would be in 6.9.6 is incorrect. It would be only if documented in the 6.9.6 release notes. At some point, we should expect an LTS migration to the 6.10.x development path, or you can choose to move there yourself.
- debumitraMar 23, 2020Tutor
My assumption that what's in 6.10.2 is also in 6.9.6 LTS is based on the heading of this: "https://kb.netgear.com/000061331/ReadyNAS-OS-6-Software-Version-6-9-6-Long-term-support-version-of-6-10-2".
The heading very clearly says: "ReadyNAS OS 6 Software Version 6.9.6 - Long-term support version of 6.10.2"
So I clearly don't understand why Netgear will call 6.9.6 an LTS version of 6.10.2 if what's in 6.10.2 is not included in 6.9.6.
Please explain.
Thank you.
