debumitra
Mar 22, 2020Tutor
Name a USB Drive - not working
I recently updated the OS to 6.9.6 which is the Long-Term-Support version of 6.10.2. The release notes of 6.10.2 say that "USB Label can be set when formatting USB". But I was unable to set the label...
Sandshark
Mar 23, 2020Sensei
You clearly don't understand how the LTS and Stable versioning works. 6.9.6 would not be derived from 6.10.2, it would be derived from 6.9.5. 6.10.3 is derived from 6.10.2. So your expectation that a change made in 6.10.2 would be in 6.9.6 is incorrect. It would be only if documented in the 6.9.6 release notes. At some point, we should expect an LTS migration to the 6.10.x development path, or you can choose to move there yourself.
debumitra
Mar 23, 2020Tutor
My assumption that what's in 6.10.2 is also in 6.9.6 LTS is based on the heading of this: "https://kb.netgear.com/000061331/ReadyNAS-OS-6-Software-Version-6-9-6-Long-term-support-version-of-6-10-2".
The heading very clearly says: "ReadyNAS OS 6 Software Version 6.9.6 - Long-term support version of 6.10.2"
So I clearly don't understand why Netgear will call 6.9.6 an LTS version of 6.10.2 if what's in 6.10.2 is not included in 6.9.6.
Please explain.
Thank you.
- SandsharkMar 23, 2020Sensei
I don't understand that title, either. 6.9.6 has been available for quite a long time, it just wasn't on the automatic update servers for some reason. As best I know, the only things it has over 6.9.5 are these:
- Fixed Microsoft OneDrive authentication issue (whihc I don't find listed in any 6.10.x release notes)
- Updated Gmail notifications to follow Google's security requirements (which is also listed in 6.10.2 release notes)
The 6.10.2 files are dated 9/23/2019 and 6.9.6 files are dated 10/20/2019. Even ignoring the numbering, that's not very long to go from stable to LTS. 6.10.2 is also quite a bit larger than 6.9.6.
