SvendSG1
Jan 31, 2015Aspirant
NAS 104 login / logout issues
I have (I believe) successfully installed the device, and I can access it from my LAN, as well as from my IOS device. However when I connect to it via the browser (192.168.0.35), I do not get a login...
Jan 31, 2015Guru - Experienced User
It sounds like you had the browser save the password. What browser are you using?
What firmware are you running?
