jdou
Jan 06, 2019Aspirant
NAS 104 Reset problem
Hi,
I had problems with my device and after having copied everything on the cloud, I have to carry out a factory reset. I tried following the instructions but from the looks of it when I reached th...
JohnCM_S
Jan 11, 2019NETGEAR Employee Retired
Hi jdou,
Please do not post your logs publicly since there some information there that should not be disclosed publicly. You may just PM the links to the NETGEAR mods nest time if we requested it.
Regarding the issue on the NAS, it appears that it already has a file system corruption. I see a lot of this message on kernel.log
BTRFS error (device md127): bad tree block start 16128832205675150423 19789628112896
It will be best to reset the NAS to factory default and restore from backup when you get 'bad tree block start'. Please try resetting the NAS to factory default. Based on the logs, factory reset was not done yet.
jdou
Jan 11, 2019Aspirant
In fact I couldn't do a factory default. I had copied the folders which I was able to open and copy and was planning to do a factory default then since I couldn't do it. Now I will copy the folders which were originally accessible before doing a factory default.
- jdouJan 16, 2019Aspirant
Hi,
I am still transferring some data but I have tried to add fuiles to teh system but it doesn't allow me. So there is still a problem.
- StephenBJan 16, 2019Guru - Experienced User
If you couldn't do the factory default from the boot menu, then I suggest doing it via the web ui. Then reconfigure the NAS and restore the data from a backup.
That's what I intended to do. Will try again.
- jdouJan 17, 2019Aspirant
Thanks, but I need to ensure that I will not loose any data I have on it prior to carrying out a factory reset. Correct?
thanks for confirming that
