jdou
Jan 06, 2019Aspirant
NAS 104 Reset problem
Hi,
I had problems with my device and after having copied everything on the cloud, I have to carry out a factory reset. I tried following the instructions but from the looks of it when I reached th...
jdou
Jan 11, 2019Aspirant
In fact I couldn't do a factory default. I had copied the folders which I was able to open and copy and was planning to do a factory default then since I couldn't do it. Now I will copy the folders which were originally accessible before doing a factory default.
jdou
Jan 16, 2019Aspirant
Hi,
I am still transferring some data but I have tried to add fuiles to teh system but it doesn't allow me. So there is still a problem.
- StephenBJan 16, 2019Guru - Experienced User
If you couldn't do the factory default from the boot menu, then I suggest doing it via the web ui. Then reconfigure the NAS and restore the data from a backup.
- jdouJan 16, 2019Aspirant
That's what I intended to do. Will try again.
- jdouJan 17, 2019Aspirant
Thanks, but I need to ensure that I will not loose any data I have on it prior to carrying out a factory reset. Correct?
thanks for confirming that
