jdou
Jan 06, 2019Aspirant
NAS 104 Reset problem
Hi,
I had problems with my device and after having copied everything on the cloud, I have to carry out a factory reset. I tried following the instructions but from the looks of it when I reached th...
Jan 17, 2019Guru - Experienced User
jdou wrote:
I need to ensure that I will not lose any data I have on it prior to carrying out a factory reset. Correct?
Correct. The disks will be reformatted, so you will lose the configuration and all the data.
jdou
Jan 17, 2019Aspirant
thanks for confirming that
