Jamesmac
Jan 10, 2017Aspirant
Nas 314 works I start to watch a movie on my Samsung 65" TV which is hard wired.
So it is wired when I start to watch a movie it will stop and then when I just go to play it again it starts from the beginning. Now I have an old Panasonic TV wirelessly accessing the Nas and I don'...
Jan 10, 2017Guru - Experienced User
It doesn't have anything to do with the TV being wired - the NAS has no way to know how the TV is connected.
If you didn't try this using the same movie on both TVs, you should.
Asusming that it is the same movie: The behavior must be built into the Samsung DLNA client. Does your Samsung support plex?
Jamesmac
I am not using plex just using like a DLNA server and the Samsung TV see's the Naz fine and I go and I have run same media on both TV's and it always glitches on my Samsung but then sometimes it won't. I find nothing in the logs but I just don't know what to try next?
- StephenBJan 10, 2017Guru - Experienced User
One option would be to try plex. It also functions as a DLNA server, so you don't need the app on all devices.
- JamesmacMay 23, 2017Aspirant
I also had the problem in the beginning and I had my ehternet setup in a different way and I downloaded Smartview from Samsung that did not work so I changed my ethernet ports to round robin and never have had the problem again. Works quite well now.
James.
