Kegsie76
Jan 25, 2022Aspirant
NAS 516 will not boot - displays "memory error"
I have a RN51600 NAS box with 6 x 3TB WD RED drives that has been working fine for years. Today the box stopped working and displays the message "memory error". Even after powering down and re-starti...
Jan 25, 2022Guru - Experienced User
Kegsie76 wrote:
I have replaced the memory but still the same Memory error.
Because of this error does it mean that my NAS is no longer functional and beyond repair?
Assuming you replaced the RAM with the proper ECC memory, then it might not be repairable. Sandshark might have some suggestions.
Kegsie76 wrote:
If so, how can I manage to retrieve the information from the disks?
It's possible but not easy.
You could purchase a 6-8 slot OS-6 NAS (516, 316, 426, 428, 526, 528, 626, or 628) and migrate the disks. Likely you'd have to purchase a used unit.
You could also get a USB enclosure (or a set of USB adapter/docks), and connect the disks to a Windows PC. From there you can use RAID recovery software that supports BTRFS (ReclaiMe). There is also some beta opensource for mdadm and btrfs, which can be used to mount the disks (free option, but might not be stable).
Similarly, connect the disks to a linux PC, and use the linux mdadm and btrfs.
Sandshark
Jan 26, 2022Sensei
One other possibility is that there is a small conductive piece of conductive FOD (foreign object debris) shorting an address line, so a good cleaning with compressed air might help. Just don't let the fan rotate while you are doing so, as it can damage the bearings.
- Kegsie76Jan 26, 2022Aspirant
I have tried cleaning the whole system with some light compressed air. I also removed the CPU and put it back again, disconnected the connections to the PCB and reconnected, and also unscrewed the PCB to look underneath it, but no luck with it getting past the "Memory error" message. There does not appear to be any burnt out components on the PCB but I would suggest the PCB is the issue. Any other suggestions?
Would I be able to restore the RAID on any newer Netgear NAS systems if I was to purchase one?
- StephenBJan 26, 2022Guru - Experienced User
Yes - I listed the relevant 6-bay models above. You can directly migrate the disks, and the system will boot up with the same config as the RN516 had. All the shares, user accounts, etc will be there.
- SandsharkJan 26, 2022Sensei
Best of luck finding anyone with new ReadyNAS to sell. StephenB didn't list rack-mount units, but any of them with 12 bays and running OS6 would also work. A legacy Intel based system with enough slots (Ultra6, Pro6, RN4200V2; NOT a 4200V1 or 3200) converted to OS6 would also work. A lot depends on how/if you plan to continue using the NAS (legacy systems will be slower) or just want to recover data.
