mitchlee83
Oct 02, 2011Aspirant
NAS Connecting to Unknown IP
My router shows that my ReadyNAS is initiating a TCP outbound connection to the following IPs: 206.16.42.240:443 206.16.42.239:443 I have no idea what these IPs are and have been unable to find...
amac27
I would suggest that you set a static ip on your NAS and check if any of the computers in the network is compromised. It would be best to isolate the network devices to pin point which is causing the network problem.
Also check the firewall setting in the router.
