oshae
Nov 30, 2014Tutor
NAS hung while copying data on 6.2
I was copying some data (200GB) from backup to my Pro 6 on 6.2. I came back after a bit and the unit was completely hung. The only thing I could do was ping it. No SMB, no web UI, no ssh, nothing. ...
oshae
Nov 30, 2014Tutor
Wow, thanks for the quick reply mdgm. As well, thanks for all the advice you have provided to my other posts these last few weeks. Logs incoming as per your Sending Logs instructions.
I was indeed using SMB to do the copy. From an internal drive in my Windows PC to the NAS. I have bitrot protection disabled and do not have snapshots enabled.
SMB is the only protocol I have enabled on this share. What other share settings can I provide you with that might help?
