lsyspsj
Feb 19, 2015Aspirant
Nas n314 locks up
I have new N314 connected to my ESX5.1 server via NFS, when I powered up a guest os the NAS will lockup totaly with in 5 minutes. I have to power cuycle the NAS to get reconnected again. Any ideas?...
mdgm-ntgr
Feb 27, 2015NETGEAR Employee Retired
Snapshots are turned on by default. For a new share created after the upgrade to 6.2 CoW is disabled by default (we link enabling/disabling CoW to enabling/disabling bitrot protection).
Looking at your logs there is a snapshot on the share. It would be best if possible if you could create a fresh share, make sure bitrot protection and snapshots are disable and try using that.
If you have a UPS, you may wish to consider enabling async: http://kb.netgear.com/app/answers/detail/a_id/14765/~/how-do-disable-nfs-sync-mode-in-readynas-os-6,-to-improve-nfs-performance
