lsyspsj
Feb 19, 2015Aspirant
Nas n314 locks up
I have new N314 connected to my ESX5.1 server via NFS, when I powered up a guest os the NAS will lockup totaly with in 5 minutes. I have to power cuycle the NAS to get reconnected again. Any ideas?...
mdgm-ntgr
Mar 04, 2015NETGEAR Employee Retired
8-10 MB of throughput sounds like you have connected it at 100Mbit not gigabit.
Could you try disabling Jumbo Frames. These may be configured incorrectly or not work with your hardware combination.
Disabling sync writes may help too (you should use a UPS if you use this).
Have you contacted our support team? There may be a different configuration issue or a tweak of some kind that may help.
You could also try our 6.2.3 beta firmware.
