Retired_Member
Dec 08, 2012Nas nv+/ nas NV+ v2 usb 3tb harddisks
I've 2 NAS (NV+ and NV + v2). I 've 3 TB harddisks (One seagate barracuda 3 TB and a western digital mybook essentials 3.0). Both NAS won't recognize these harddrives on the USB port. I've also a 2 TB...
Retired_Member
Dec 24, 2012
evan wrote: NV+ can not support more than 2TB partition,
For NV+ v2, which USB port do you connect? USB2.0 or USB3.0, pelease try to connect to USB2.0 which is the front USB port on NV+ v2, USB3.0 has compatibility problem, please see below link that is Official USB 3.0 Device HCL for NV+ V2 and Duo V2.
http://www.readynas.com/forum/viewtopic.php?f=109&t=66486
I've connected to the front port of the nv2+
i've tried seagate baracuda 3tb drive in a sharkoon device and
i've tried wd mybook 3 tb , this is an external harddrive
both are formated as ntfs. (i can't switch them anymore for 2 tb drives)
Can divide the drives in 2tb partitions help?
The problem is my old pc has only usb 1.2, with xcopy, it's very, very, very slow
with my laptop i use robocopy (windows 7, 802.11n, usb 2.0) is also very slow.
