gerritreijnders's avatar
Jan 12, 2022
Ready nas NV+ booting problem HDD?
Hi, I have a readynas NV+,with 4 HDDs of 2TB. Suddenly I couldn't access my files anymore.
Did a reset but it hangs on booting. It also failed to get to the front page via Raidar.
I bought a 2nd hand Readynas NV+, with 4 1TB.
I put the 4x1TB HDD drives in my own Readynas NV+ and it works well.
so the problem is not the readynas nv+ itself.
I put my own 4x2TB hdd in the bought 2nd hand readynas nv+.
Now it's this one hanging with the same drives (my 4x2TB) on boot.
How do I find out which disk is broken, or have I really lost everything.
How do I find out, and is there anything to fix,
all family videos and photos are on it, and more important information.
I used translate, thanks.
  • gerritreijnders's avatar
    gerritreijnders
    Jan 20, 2022
    Problem solved.
    hooked up 3 HDD to a desktop Computer
    With recovery software, it could find all maps. 5,4TB
    and it was all possible to recover.
  • StephenB's avatar
    Unfortunately, you have learned that RAID isn't enough to keep your data safe.  Hopefully you can get it back, and then put a backup plan in place.
    What kind of reset? A factory default (sometimes called factory reset) is destructive.
    Can you connect the disks to a Windows PC (either with SATA or a USB adapter/dock)?  If so, try testing them with vendor tools - Seatools for Seagate, WD's Dashboard for WDC.  Run the long generic test on each (which will take a couple hours).
      gerritreijnders
      i hold the reset button power button for 5 seconds the leds go on.OS
      I did a memory test but thats ok.
      Now they are in the NAS almost a day, booting ...
      led 123 are on
      led 4 is blinking
      Power button, first blinking, now solid blue.
      Raidar
      Status, system is starting
      IP adres 192.168.168.168
      Else i cant do nothing with Raidar
      All HDD are the same WD20EARX  2TB
      The test i will try.
      Thanks so far.
        gerritreijnders
        Problem solved.
ProSupport for Business
