wazza69
Jan 29, 2014Aspirant
NAS outside of IP Range
Hi, We have moved address and changed broadband supplier and my ReadyNas v1 no longer shows on the new router (Was VirginMedia, now BT in the UK) Under my old system, I think my NAS must have ...
vandermerwe
Jan 29, 2014Master
Do you have a backup of your data?
Is your mac using dhcp or a static ip address?
Do you have RAIDAR installed on your mac?
http://kb.netgear.com/app/answers/detail/a_id/20684/
You should be able to see the nas on radiar and access the admin pages to change to dhcp or set a fixed ip address in the correct format.
What ip address is displayed on raidar?
Alternatively log in to the new router admin pages and change both the ip address of the router to 192.168.0.1 and the dhcp address range to 192.168.0.x - 192.168.0.y. Make sure the subnet mask is 255.255.255.0
There is some guidance here:
http://bt.custhelp.com/app/answers/deta ... ome-hub%3F
Also if you were to change your mac ip address to 192.168.0.y (fixed) you should also be able to access the nas at its current ip address, this won't solve the problem completely though because your gateway address will still be 192.168.1.1.
